Hi, welcome to the forum.
If it has sat for a long period of time, I would suggest some fresh fuel, fuel filter, and a tune up. You could also run some injector cleaner through a couple tanks of gas.
Also pull the codes from the eec.
Brett
Problem!!!
I would check fuel pressure at the shrader valve, should be around 40psi after cranking the key to on a few times, could be a stuck fuel pressure regulator. I wouldn't be surprised if it was an injector acting up either, they don't like sitting for long periods of time but usually clear up before long with new fuel.
-Mike S.
-Mike S.
