In need of some diagnostic help
Check and clean mass air ...
Pull the mass air meter out and inspect the two little wires. if dirty they can cause problems. I had that same issue only at around 2500 rpm. I replaced everything from fuel pump to ign stuff.. everthing...stil had issue.. I found a small hair hanging off one wire in the mass air.. once you got to 2500 rpm it made contact with the other wire..that was my issue.. just use the correct mass air meter cleaner. hope this might help.
mass air
you will need a torx head too pull out the meter.. clean the lil sensers(wires) inside. easy to do hopefully that does it...
mass air
oh yeah sorry .. i forgot about that.. I Have had my 93 for 15 years now.. I had to make a special trip to harbor frieght to get that one, it's been a while. I think you'll find out that fix's your problem. I had replaced everything that your looking at.. including a 255lph fuel pump..and a dirty mass air was the problem.
mass air
Glad to hear it's running! I figured that I was the only one with the dirty mass air..That was just my luck.
# 4218
Just think the car got some blood, sweat, and tears from you today. Better not tell the girlfriend/ wife she will be jealous!!
