Need more HP!
Need more HP!
Has anyone used the water/methanol combo from Snow Performance on their '93's? Was it worth the $? Thanks!
Here are the mods, sorry!
Vortech T-trim Supercharger @ 11 lbs. of boost
-Adjustable Fuel Pressure Regulator
-MSD Boost Controller
-MSD 6A Ignition Module
-Taylor 10.4mm Ignition Wires
-Cold Air Kit
-Auto Meter Boost gauge A-pillar mounted
-Vortech T-Rex secondary Fuel Pump
-Steeda Lowering Springs
-Steeda Lower G-Bar
-Steeda Strut Tower Brace
-Steeda Tubular Sway Bar
-Steeda Upper and Lower Control Arms
-Ford Motorsport Subframe Connectors
-Front Tokico 5 way adjustable Struts
-Rear Tokico 5 way adjustable Shocks
-Lakewood Driveshaft Loop
-Ford Motorsport Cobra R Brake kit 5 Lug w/13" dual piston front rotors & 11.65" rear rotors
-3:73 Ford Motorsport rear gear set
-T-5 World Class 5 speed transmission
-Centerforce Dual-Friction 3 clutch
-BBK 1 5/8 Shorty Headers
-MAC Cat-back Exhaust with Chrome 2 1/2" tips
-MAC X-Pipe (original cats included)
-Cold Air Kit
-Steeda Lower G-Bar
Re: Need more HP!
I hear it makes a difference, but from what I read at Kenne Bell, you have to get the right jet for your setup, and retune for the meth injection. Problem is if you let it run out, then you are tuned wrong. If you are getting detonation, maybe an intercooler is in your future. What octane fuel are you using with 11lbs of boost? Any addatives?Want Teal '93 wrote:Has anyone used the water/methanol combo from Snow Performance on their '93's? Was it worth the $? Thanks!
93 Cobra, Kenne Bell 2.1L, 42# injectors, 76mm C&L MAF and inlet tube, MM sub frames & K-brace, Hurst SST shifter, Moates QuarterHorse, DataQ, BE/EA tuning software, Flowmaster cat backs, Autometer gauges.
68 Shelby GT-350 in restoration
Well, if I were you I would just get a different pulley. That T-trim is not even feeling that 11 lbs of boost, crank it up to about 15. Of course, if you still have the stock block, you are probably already close to the edge with your current combo. What kind of power are you currently making?
1993 COBRA #4975
Teal/Black cloth
Teal/Black cloth
11lbs of boost sounds like alot for 91 octane acording to what I have read (Im certianly not an expert, just read alot)Want Teal '93 wrote:The block is stock, along with heads, etc. I am using 91 fuel, is that high enough octane? I have not had it on the dyno, was thinking about taking it down and having everything ran through to double check. 93inAZ, can you recommend a shop in Phoenix? Thanks!
If you are looking for the best dyno tune around take it to Arizona Dyno Chip, Keith is THE man when it comes to tuning, especially Mustangs. He can even burn you a custom SCT chip. He has all of the right equipment and he is very knowledgable, I have personally seen him take an '05 Mustang with a Vortech from 418hp when it came to 501hp when it left 3 hours later, it just depends on how far off your current tune is. Tell him that Greg sent you!Want Teal '93 wrote:The block is stock, along with heads, etc. I am using 91 fuel, is that high enough octane? I have not had it on the dyno, was thinking about taking it down and having everything ran through to double check. 93inAZ, can you recommend a shop in Phoenix? Thanks!
1993 COBRA #4975
Teal/Black cloth
Teal/Black cloth
Snow Boost Cooler
I am using the Snow Boost Cooler on my Cobra it made about 55 extra HP.......516 FW & 446 RT
Dave Trangmar
