Stock Cobra Motor Picture
absvtford
Post by absvtford »
Hey guys - does anyone have a clear, detailed picture(s) of a stock 93 cobra motor from the top of the motor? I am looking at a picture of a motor and can tell some things are different. Would like to compare to a completely stock motor.
Also, what color were the stock distributor cap wires?
Thanks for your help
408lx
Re: Stock Cobra Motor Picture
Post by 408lx »
Below is a stock motor picture, the original wires would be grey and the boot ends black. If they are factory wires they will say motorcraft, be stamped with the year 1993 and be numbered to the designated cylinder.
92 GT white on grey leather
89 LX notch black on grey 408ci efi
93 Cobra red on leather #468
Here is one, I also have a few more detailed pictures of sides if you need anymore. Like 408lx said about the wires.
absvtford
Post by absvtford »
Thanks guys.
Looking at a car that has the camber caster covers changed out (not black). What could this be indicative of? I am wondering if the car was hit in the front (although all VIN tags appear on the fenders and bumper.
I have heard that a plate which notes "cobra" comes from factory behind the front bumper of these cars, drivers side. Exact location unknown. Have you guys seen this on your cars?
the plate is about 2" by 4" and is in between the driver headlight and the radiator support, it is stapled to the radiator support.
look at photo below
absvtford
Post by absvtford »
Thanks 1993. Much appreciated.
Some of these cars the camber is off, with the stock setup they don't always get it adjusted correct. So most people just put an aftermarket setup on them.
Nothing against the Ford factory setup, but for much improved handling on these cars an aftermarket caster/camber setup along with some choice suspension mods is the way to go.
Mustang_Scotty
Post by Mustang_Scotty »
1993 VR Cobra #2209 SOLD
2006 Vista GT SOLD
2008 Vista Shelby GT Vert SOLD
2009 Vista GT500 SOLD
2009 Vista GT500 Vert SOLD
2009 Vapor C/S SOLD
2009 Vista GT500KR SOLD
2012 Sterling MCA Edition SOLD
1993 VR Cobra #4057
SOLD
2016 GT350 SOLD
absvtford
Post by absvtford »
Was the engine oil fill cap originally black or gray on these cars?
absvtford wrote:Was the engine oil fill cap originally black or gray on these cars?
No they are black with yellow writing , see photos above
^ that teal still has remanants of the white factory chalk on thr air inlet tube, also has the white X on the airbox, has the orig white ford sticker on the radiator and the purple dot paint on the caster camber plates, also look for the "AB" in pink on the drivers valve cover, orig alternator will say "GT" at the top, if its bone stock ever hose should say ford on it. Look for the small ford oval on every light in the front, tailights with have ford oval and the second stripe up from the bottom is the only one that does not go all the way across.
Hey, bdecoy. Did you replace that Interstate battery with a Motorcraft one yet?
Z I believe esco did...
Also the valve covers have original sticker. Also why does the hose above gt40 intake have black coil cover? That's not original
