Type of Gas
Posted: Sun Dec 20, 2015 1:12 am
by lukewood2
Since I've had my car I've always put 91 in it. What are you guys running for stock engines? Is it worth it or should I go to 87?
Re: Type of Gas
Posted: Sun Dec 20, 2015 7:22 am
I always try to run the highest grade available, I have heard guys talk about running 87 and such. Here is some previous conversation about the grade of gas: viewtopic.php?f=1&t=52&hilit=grade+of+gas
Re: Type of Gas
Posted: Sun Dec 20, 2015 10:39 am
by lukewood2
WillyB93 wrote:I always try to run the highest grade available, I have heard guys talk about running 87 and such. Here is some previous conversation about the grade of gas: viewtopic.php?f=1&t=52&hilit=grade+of+gas
Awesome thanks!
Re: Type of Gas
Posted: Sun Dec 20, 2015 5:23 pm
Years ago, 93 octane gas had superior detergents, etc. and was better quality than 87 or 91. Today, all grades of gas are the same from a quality and refining standpoint. Today, you should use whatever grade is recommended by the car manufacturer and not have to worry about the quality of the gas. For a stock 5.0 (Cobra or LX/GT), 87 is perfectly fine. Anything else, and you're wasting money.
Also, 87 octane is what's recommended in the Owners Manual of these cars.
Re: Type of Gas
Posted: Sun Dec 20, 2015 8:06 pm
by lukewood2
Z282SLO wrote:Years ago, 93 octane gas had superior detergents, etc. and was better quality than 87 or 91. Today, all grades of gas are the same from a quality and refining standpoint. Today, you should use whatever grade is recommended by the car manufacturer and not have to worry about the quality of the gas. For a stock 5.0 (Cobra or LX/GT), 87 is perfectly fine. Anything else, and you're wasting money.
Thanks man. Going to switch it up and see what happens. Gas isn't cheap in Cali...
Re: Type of Gas
Posted: Tue Dec 22, 2015 2:20 am
by Psychokinesis
87 is fine..i do the 1 to 3 method. 1 tank 93 and 3 tank 87..i even run the same ratio in my shelby because i dont beat on it..no issues what so ever,
Re: Type of Gas
Posted: Tue Dec 22, 2015 9:02 am
by 93Cobra#2771
If your car has stock timing and isn't chipped, 87 is fine. If timing has been bumped to 14° or car is chipped, you need to stick with 93 octane.
More important than octane, to me, is having 100% gas, as opposed to ethanol blend...
Newer cars with knock sensors, however, DO take advantage of 93 octane with higher HP output and sometimes better gas mileage. I run 93 in my ecoboost f150 (I tow a lot and it is actually worth 15hp or so). I also run 93 in our turbo Sonata, as I like to hit the skinny pedal occasionally. :-)
Re: Type of Gas
Posted: Tue Dec 22, 2015 3:12 pm
by lukewood2
Thanks!
