Dash repair. Ideas??
canzo116
Post by canzo116 »
Dash is scuffed due to previous owner putting a cobra symbol where pony used to be. Since been replaced with correct emblem but now there's damage. Any way to fix this? Wet sand and paint?
1993 Cobra #2476
Re: Dash repair. Ideas??
canzo116 wrote:Dash is scuffed due to previous owner putting a cobra symbol where pony used to be. Since been replaced with correct emblem but now there's damage. Any way to fix this? Wet sand and paint?
Is that adhesive material still on the dash, or a scrape? If it is adhesive material, try using mineral spirits on a rag and wipe the area gently to remove.
Psychokinesis
Post by Psychokinesis »
I am having the same problem.. Havent tried anything yet..why people put snakes there, already had the horse.....venting....
If the surface is not scratched and you're just trying to remove adhesive quickly and easily, get some "Goof Off". It's by far the best adhesive remover I have ever used. However, the stuff is strong so I would use it sparingly and gently on the dash surface.
