#103 51k
Re: #103 51k
Got some pictures of the 04?
Re: #103 51k
I use to own this car years ago. Was nice but had a little paintwork.
Re: #103 51k
Yes it does. Thats why I am giving it away.i did a lot of suspension amnd drivetrain work to it.the paint does need work I just dont have the time to do two projects. This is a solid car and a good paint job would be 6k. Thats why my price is low. Especially with the amount of miles on it. Ive seen over 100k goin for more.
# 103 cobra teal
2004 cobra comp orange
Re: #103 51k
No I mean it has had some paint work. The car was mint when I had it but the right front fender had been repainted.
Re: #103 51k
Yeah. I thought so too. The tag is different than the others
# 103 cobra teal
Re: #103 51k
Here are some of the pics for my 93. As you can see its pretty clean. I did all the suspesion work myself alomg with drilled and slotted rotors and brand new falken fk452 tires and painting the calipers black. I also did the factory undercoatimg in the wheel wells over along with undercoating the back half which was also done factory. I bought the car with a flowmaster kit which was rusty so I bought a new one. I also put bbk equal lengths and x pipe on. I retained the factory headers and h pipe along with crossover and air pump to be changed back if nessecary. I bought a energy suspension kit with kyb and eibach pros. I also put in a frpp king cobra clutch with bbk quad and cable along with a mgw shifter and a stiffler crossmember for the transmission, the only reason I put a clutch in was because the bearing was chirping. I also put a new rear main in at the same time just because I was there. I put in moog ball joints and moog tie rods along with new control arm bushings from energy suspension. On the rear end I put sve control arms with energy suspension axle eyelet bushings. I put a bbk cold air on but I kept the factory air box and tube so It can all be changed back if nessecary. I took a lot of time on this car and want to see it go to a good home. I did have plans to get it all repainted but I came across a 2004 comp orange cobra and am only allowed one project. Lol
I also have the factory radio which big surprise doesnt work very well so I replaced it with a cd player, I also habe the svt certificate framed along with original window sticker framed and a build spec sheet from ford also framed. I am open to offer but please dont waste my time with a low ball. I would like to get 12500 obo. Please feel free to txt or call 4zero28eight9zero 0three2
Thanks Matt
Thanks Matt
# 103 cobra teal
