Airbag diagnosis codes
Re: Airbag diagnosis codes
Get an ohm meter and I'll pm you my phone number and tell you the steps, I'm betting you need a clock spring.
AIRBAG REMOVAL
AIRBAG INSTALL
DESCRIPTION OF CODE
POSSIBLE CAUSES
TEST PROCEDURE PIC1
TEST PROCEDURE PIC2
TEST PROCEDURE PIC3
TEST PROCEDURE PIC4
AIRBAG MODULE CONNECTOR DIAGRAM
CLOCKSPRING REMOVAL
CLOCKSPRING INSTALL
CODE 32 SYSTEM SCHEMATIC
Man...thanks a lot!!!! This will def come in handy. Can you after market steering wheels on these cars? If so, is it a pretty simple swap?
So I was driving the cobra today and decided to turn the a/c on since wifey was with me and it was pretty hot out, I never use it, then the airbag light was flashing, counted 4 four or three times then a long pause then it did it again, I was so pissed, whenI got home I waited a few minutes, went to crank her up and waited for the flash and no flash, then I turned the ac again and no flash, any:help: on this would be appreciated, I'm confused about it too
scootro
Post by scootro »
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
Continuous Air Bag Indicator - Diagnostic Trouble Code Timed Out, Diagnostic Monitor Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor.
12 Lost Battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to Battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open (See the Prolog)
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 RH Radiator Primary Crash Sensor Feed/Return Circuit Open
42 LH Radiator Primary Crash Sensor Feed/Return Circuit Open
44 RH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
45 LH Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
52 Intermittent or Repaired Lost Battery Feed
53 Intermittent or Repaired Air Bag Circuit Shorted to Ground
54 Intermittent or Repaired Primary Crash Sensor Circuit Shorted to Ground
61 Intermittent or Repaired Diagnostic Monitor Not Mounted to Vehicle Properly
62 Intermittent or Repaired Safing Sensor Output Circuit Shorted to Battery Voltage
63 Intermittent or Repaired Memory Clear Circuit Improperly Grounded
64 Intermittent or Repaired System Disarm Failure or Internal Diagnostic Monitor Fault
72 Intermittent or Repaired Driver Side Air Bag Circuit High Resistance or Open
73 Intermittent or Repaired Passenger Side Air Bag Circuit High Resistance or Open
74 Intermittent or Repaired Driver Side Air Bag Circuit Low Resistance or Shorted
75 Intermittent or Repaired Passenger Side Air Bag Circuit Low Resistance or Shorted
81 Intermittent or Repaired RH Radiator Primary Crash Sensor Feed/Return Circuit Open
82 Intermittent or Repaired LH Radiator Primary Crash Sensor Feed/Return Circuit Open
84 Intermittent or Repaired RH Radiator Primary Crash Sensor Not Mounted to Vehicle
85 Intermittent or Repaired LH Radiator Primary Crash Sensor Not Mounted to Vehicle
Rapid Continuous Flashing of Air Bag Indicator (No Diagnostic Trouble Code) Both Primary Crash Sensors Disconnected Assembly Plant Mode
Keepin' The Old School Alive
scootro
Post by scootro »
vinchez78 wrote:So I was driving the cobra today and decided to turn the a/c on since wifey was with me and it was pretty hot out, I never use it, then the airbag light was flashing, counted 4 four or three times then a long pause then it did it again, I was so pissed, whenI got home I waited a few minutes, went to crank her up and waited for the flash and no flash, then I turned the ac again and no flash, any:help: on this would be appreciated, I'm confused about it too
count the number of flashes look for short and long pauses. example flash,flash,flash,pause,flash,flash long pause = 32 each will repeat 3 times, then the next code will flash if there is a second code.
Thanks for the info fellas, I'm not gonna use the ac anymore for fear of seeing the dreaded flash :shock:
vinchez78 wrote:Thanks for the info fellas, I'm not gonna use the ac anymore for fear of seeing the dreaded flash :shock:
Wifey won't be pleased...
Might mess her hair up with the windows down also.
fjoconnell
Post by fjoconnell »
I saw the Crappy flash in my wife's 93 convert and didn't know why it started all of the sudden. I have the windows down most of the time myself. I'm going to take it out today with no A/C and see what happens.
93 Cobra Teal/Gray #4893
93 LX 5.0 Convertible (Wife's)
87 LX 5.0 Coupe (Sold)
90 LX 5.0 Convertible (Stolen)
93 LX 5.0 Hatchback (Sold)
88 LX 5.0 Coupe (Sold)
Nah, she'll be alright, she actually told me not to turn the ac on in the first place since the car is "old" and something might happen, guess she knows her cobras :?
She sounds like a keeper, Brah...
Hate to disagree with your better half, Vin. ;) However, you should be able to turn on your A/C and not have a flashing airbag light, even in a 20-year-old car. Hopefully the info in this thread will help you figure out what's wrong and it'll be an easy fix.
I love cruising in the Cobra with the windows down, but sometimes the A/C is a must in my neck of the woods during the summer. I'm sure it's the same down in Georgia. Good luck.
Ya it sure is hot as shit in Georgia Z, it's strange but I haven't seen it flash anymore, even today when I was testing it out with the ac , wonder why it only did yesterday, hope it's the only time
Electrical gremlins. :evil: They're a pain in the ass.
