Airbag diagnosis codes
Listed in order starting with highest priority
12 - low battery voltage
13 - airbag circuit sensors shorted to ground
21 - safing sensor not mounted to vehicle properly
22 - safing sensor output shorted to battery voltage
23 - safing sensor input feed / return circuit open
24 - safing sensor output feed / return circuit open or low resistance in a primary crash sensor
32 - driver side airbag circuit high resistance or open
33 - pin 7 not grounded
34 - driver side airbag circuit low or shorted
35 - pin 8 and 9 shorted together
41 - primary crash sensor circuit high resistance or open
44 - rh headlamp primary crash sensor not mounted properly
45 - center primary crash sensor not mounted properly
46 - lh headlamp primary crash sensor not mounted properly
51 - diagnostic monitor internal thermal fuse blown
52 - backup power supply voltage boost fault
53 - internal diagnostic montitor fault
rapid flashing - all primary sensors disconnected
no light - no ignition voltage to diagnostic monitor
continuos light - diagnostic monitor disconnected or innoperative
- Phistry810
- Phistry810
No, would that work? Can I get to it by removing the AC control panel instead of the radio? Also, did you see my response/picture on the other thread?
- Phistry810
- Phistry810
Looking at my owner's manual, it says fuse #18 is for:1993cobra wrote:looking at the manual to kill the light it , you would have to disconnect pin 1 or pin 6 to the module. seems completely disconnecting the module would cause the light to stay on steady. try fuse #18 its a 15 amp fuse that supllies power to the lamp, pin1, and pin 6.
-Safety Belt Chime
-Warning Lights
-Fuel Injection Circuits
-Tachometer
-Idle Tracking Air Control
-Choke Restart Control
-Cooling fan/Compressor Clutch Control
So...I am afraid to remove that fuse. Fuse #7, also a 15 amp fuse, is listed as -Air Bag System. I took this one out and light still blinks.
Should I still try #18?
While the chirp/blinking light may be annoying, you sure the solution is to disable your airbag?Phistry810 wrote:Can anyone post the steps on what to do to disable the airbag in a way where the light doesnt flash and the module doesnt chirp?
That may be a fix worth doing properly so your Cobra has a functioning air bag if ever needed.
- Phistry810
I don't have one, how would that help? Should I buy one?1993cobra wrote:do you have an ohm meter? i can walk you through the steps to find the problem.
