275/40/17's on stock 7.5 rims
JD136965
Post by JD136965 »
Anybody running 275/40/17's on their stock back wheels? Thinking about running more width in the rear and wanted to know how they would work on the Cobra's 17x17.5 wheels. At the moment I'm running the stock 245/45/17 all the way around.
Re: 275/40/17's on stock 7.5 rims
They are too pinched in, they distort the tire, which affects contact patch, gives wonky handling as the tire squirms around, and look funny. Your best best is to run the aftermarket repro wheels on the back, which are 8.5", and can accommodate the 275/40S.
JD136965
Post by JD136965 »
Thanks for the suggestion. Have a good pair of 275's sitting around and thought about putting them on to fill out the rear more. I may look into the wheels eventually for sure. Thanks again!
But they will work
Cobra18
Post by Cobra18 »
Anybody have pictures of this tire on the stock rim?
Meegs
Post by Meegs »
275 nitto 555R's on stock 7.5
Next to 315/35r17 Nitto's on 10.5" cobra rims.
.Image
93Cobra#2771
Post by 93Cobra#2771 »
They will work, but be advised some tires run wider than other tires. Nitto drags run narrow (have them on the rear on stock rims). I've seen other brands that looked OK as well.
The above pic with the drags on the repro wheel is SICK! :drive:
351wlx
Post by 351wlx »
Meegs wrote:275 nitto 555R's on stock 7.5
.Image
What company did you use to widen your wheels? If you don't mind me asking, what did they charge?
Ysi91
Post by Ysi91 »
275's on the stock wheel.
91 coupe vortech ysi
93 coupe 91mm turbo
03 Mach1 built shortblock 60mm turbo
93 teal cobra s-trim
Ysi91
Post by Ysi91 »
93 coupe 91mm turbo
Ysi91
Post by Ysi91 »
More with the 275
93 coupe 91mm turbo
