Speedo Gear Question
harleyreb1
Post by harleyreb1 »
I'm going to 3.55 rear gears anyone know the correct color speedo gear?
1993 Cobra # 501
Dantak
Post by Dantak »
I asked this question like 3 weaks ago. Check out this chart from Steeda. I'm pretty sure you need an 8 tooth.
http://www.steeda.com/products/speedome ... _gears.php
Post by ceetwarrior »
nah dude he needs a 23. Aftermarket is white for the Cobra T-5. Did mine a few months back.
Dantak
Post by Dantak »
uhhh...yes of course he needs a 23, i'm pretty sure they are all 23, but steeda sells 2 different sizes of the other part of the speedo gear. 7 tooth and 8 tooth.
just look down about 20 post and you will see this
viewtopic.php?t=566
white 23 tooth gear
Yeah, but why would he change the tranny gear when it's easier to change the 23t cable gear!!
Dantak
Post by Dantak »
your not following me. Look at the link I posted. Steeda sells 2 different white 23 tooth speedo gears. One of them has 7 teeth on the other side and the other has 8.
Ah, I got ya.
