Water Pump NOS or OEM
aaronlstiles wrote:
JohnLynch wrote:Got my pump today. False advertising shows ford stamp on the website but it has a sticker says fomoco made in china :(
I hate to say I told you so, If you want a NOS pump, you will pay top dollar. I have a few, but dont want to sell.
Also, you may have good luck at NAPA with a reman pump. Most of there re-man pumps are original ford housings. May be the same with autozone, all I can say is check it out.
I was not a fan of that Ford sticker, made in China!!
Well I had already ordered it before you told me, but if you go on to this link you will see it has a ford stamp as advertised;
http://www.americanmuscle.com/ford-waterpump-8693.html
trackpilot wrote:I think John was talking about the sticker and it not having the original Ford stamp. Not about where it's made.
Actually I was hoping it wasnt made in China, I dont want to give those commies any of my money. I just wish someone would start making American parts in America.
I called to the local autozone and they have one made by some brand calld Tuff something or other.
I might give these guys a call in NY and see how much to rebuild the original.
NoSloCoupe
Post by NoSloCoupe »
Why wouldn't you just buy a part like this local?
NoSloCoupe wrote:Why wouldn't you just buy a part like this local?
Wanted FORD American made.
Just send yours to a company like the one in the link I posted and your good!
I basically paid an extra $10 because Ford put it in a FORD Racing box!! I just think thats a bunch of sh%$.
Its advertised as a FORD stamped part so they are letting me return it free of charge. My point is if I knew it was just from china anyways I could have went down to autozone and bought one for $34 same day I needed it instead of waiting 4 days for this crap to get here.
u feel me bro?
The guy at american muscle told me half of my 93 Cobra was made in China but I begged to differ.....sorry for being a patriot 8)
NoSloCoupe
Gotcha, i just figured you knew basicly all ford and ford racing is china made now.
1993cobra wrote:Just send yours to a company like the one in the link I posted and your good!
I called them good lead thanks, they said 2 day turnaround and $85......
Now before I take off this water pump is there a way to know for sure it is leaking? When I had my rear main seal repaired the Mechanic told me it was but I dont see any water on the ground.....
Most the time they leak from the backing plate bolted to it sandwhiched between the front cover and pump. Or they leak from the weap hole just below where the pulley bolts on.
In this tread it shows the backing plate mounted to the back of the water pump, notice the two bolts on the bottom.
http://forums.corral.net/forums/5-0-5-8 ... -93-a.html
WillyB93 wrote:Most the time they leak from the backing plate bolted to it sandwhiched between the front cover and pump. Or they leak from the weap hole just below where the pulley bolts on.
Should I be seeing water on the ground in the garage?
Get small mirror on a telescoping handle and look at the bottom side and see if the weep hole is damp or dripping.look at the plate while your looking.
Depends on how bad it is leaking, you might see it on the K frame or the rack and pinion if slightly leaking.
leaking slightly from the weep hole.... :( sucks because I just replaced the water pump on my truck the other day what the hell is going on...
JohnLynch wrote:leaking slightly from the weep hole.... :( sucks because I just replaced the water pump on my truck the other day what the hell is going on...
That time of the year, better watch out the battery's might be next.
casper
Post by casper »
seals get cold and skrink, kinda like walking into cold water up to belt line :shock:
