1993 cobra steering wheel wanted
Not if you know how to.
NPD Florida, is very close to here, I mean real close
NPD "SPC" Part Number Ford Part # Description Application Retail
SPC-29170-FL F3ZZ-1007-E WHEEL, ALUMINUM 5-SPOKE M 93, WHITE, CORRECT FOR FEATURE CAR $84.95
SPC-27933-FL E9ZZ-1A043-A LOCKING LUG SET M 89 & UP, CORRECT FORD KIT $16.95
SPC-29200-FL F1ZZ-3600-A STEERING WHEEL, LEATHER M 91-93 WITHOUT CRUISE CONTROL, BLACK CORRECT FOR '93 COBRA!!! NEW IN BOX, WRAPPED IN PLASTIC WITH TAGS, THE VERY SAME CONFIGURATION AS WHEN THE CARS WERE DELIVERED BRAND-NEW. PERFECT FOR CONCOURS AND FUTURE THOROUGHBRED SHOWING. $349.00
SPC-23641-FL E7ZZ-3A719-A PWR STEERING HOSE, PRESSURE M 87-89 2.3 4-CYL, PUMP-GEAR $10.00
SPC-29205-FL F3ZZ-4010-A AXLE HOUSING/CARRIER M 93 COBRA, TAG 201A, THESE ARE FULL COBRA 8.8” HOUSINGS, BARE. THEY DO NOT INCLUDE GEARS, AXLES, OR BRAKES. $300.00
SPC-29206-FL F3ZZ-4602-A DRIVESHAFT ASSY M 93 COBRA, COBRA DRIVESHAFTS ARE UNIQUE FROM STANDARD 5.0 SHAFTS DUE TO STRICTER BALANCE/BETTER BALANCE TOLERANCES. $149.00
SPC-27939-FL E8ZZ-5230-F MUFFLER/TAILPIPE ASSY, LH M 88-93 5.0 LX, LH, FULL FACTORY ASSEMBLY, INCLUDING BRUSHED STAINLESS TAILPIPE, N.O.S.. SOME ARE SLIGHTLY DAMAGED, WE'LL SELL ALL THE PERFECT ONES FIRST. $139.00
SPC-23664-FL E5ZZ-9430-A EXHAUST MANIFOLD M 83 2.3 4-CYL, EXCEPT TURBO $60.00
SPC-23669-FL E5ZZ-9A758-B CABLE, THROTTLE M 83-86 2.3 4-CYL, EXCEPT TURBO $9.50
SPC-23540-FL F0ZZ-13404-A LAMP ASSY, REAR TAILLIGHT, RH M 90-92 GT, TWILIGHT BLUE $135.00
SPC-23541-FL F0ZZ-13404-D LAMP ASSY, REAR TAILLIGHT, RH M 90-92 GT, EMERALD GREEN $135.00
SPC-30912-FL F1ZZ-13404-A LAMP ASSY, REAR TAILLIGHT, RH M 91-92 GT, MEDIUM RED $135.00
SPC-23439-FL F1ZZ-13404-C LAMP ASSY, REAR TAILLIGHT, RH M 91-92 GT, MEDIUM TITANIUM $135.00
SPC-23455-FL F1ZZ-13404-D LAMP ASSY, REAR TAILLIGHT, RH M 91-92 GT, TITANIUM FROST $135.00
SPC-23543-FL F2ZZ-13776-A LAMP ASSY, DOME M 92, SCARLET $25.00
SPC-23617-FL F1ZZ-14401-A HARNESS, UNDER-DASH M 91 ALL, COMPLETE UNDERDASH WIRING, NEW! $350.00
SPC-29173-FL F3ZZ-14588-A WIRING ASSY, RADIO M 93 COBRA, W/SUBWOOFER & AMPLIFIER SOUND SYSTEM $25.00
SPC-23685-FL F1ZZ-16005-A FENDER, RH M 91-93 ALL, RH $279.00
SPC-29193-FL F2ZZ-16055-A APRON, INNER FENDER, LH M 92-93 ALL, LH, MAY ALSO WORK ON EARLIER YEARS. THIS IS A FULL APRON, INCLUDING SHOCK TOWER, SPANNING FROM THE FIREWALL TO THE RADIATOR SUPPORT. IF YOUR MUSTANG HAS BEEN WRECKED OR CUT, THESE ARE THE ONLY REMAINING N.O.S. APRONS YOU'LL LIKELY EVER FIND $199.00
SPC-23622-FL D9ZZ-16228-B ORNAMENT, ROCKER PANEL M 79-93 ALL, SMALL FORD OVAL PLATE THAT STICKS BELOW SCUFF PLATE $9.95
SPC-22383-FL D9ZZ-16612-A HOOD PANEL M 79-82 STANDARD $450.00
SPC-29194-FL F2ZZ-17255-D SPEEDOMETER ASSEMBLY M 92-93, 140 MPH $119.00
SPC-23629-FL E3ZZ-17618-C RESERVOIR, W/SHIELD WASHER M 80-83, WITHOUT LOW FLUID SENSOR $40.00
SPC-27946-FL E7ZZ-18472-A HEATER HOSE, OUTLET M 87-90 2.3 4-CYL $5.00
SPC-23632-FL E9ZZ-18806-G RADIO M 89-90 AM/FM CASSETTE W/CLOCK, PREMIUM SOUND $295.00
SPC-23561-FL F0ZZ-19893-A REGISTER/VENT, A/C, LH M 90-92 SCARLET $29.00
SPC-23633-FL F0ZZ-19893-D REGISTER/VENT, A/C, LH M 90-92 TITANIUM $29.00
SPC-23634-FL F0ZZ-19893-F REGISTER/VENT, A/C, CENTER M 90-92 SCARLET $59.00
SPC-23563-FL F0ZZ-19893-G REGISTER/VENT, A/C, CENTER M 90-92 CRYSTAL BLUE $59.00
SPC-23635-FL F0ZZ-19893-P REGISTER/VENT, A/C, RH M 90-92 TITANIUM $29.00
SPC-29214-FL F3ZZ-7603136-AAF WINDSHIELD MOLDING, RH VERTICAL M 93 CONVERTIBLE, YELLOW FEATURE CAR $65.00
SPC-29215-FL F3ZZ-7603136-AAZ WINDSHIELD MOLDING, RH VERTICAL M 93 CONVERTIBLE, WHITE FEATURE CAR $65.00
SPC-29216-FL F3ZZ-7603137-AAZ WINDSHIELD MOLDING, LH VERTICAL M 93 CONVERTIBLE, WHITE FEATURE CAR $65.00
SPC-29217-FL F3ZZ-7603145-AAF WINDSHIELD MOLDING, LH TOP M 93 CONVERTIBLE, YELLOW FEATURE CAR $65.00
SPC-29218-FL F3ZZ-7603145-AAZ WINDSHIELD MOLDING, LH TOP M 93 CONVERTIBLE, WHITE FEATURE CAR $65.00
SPC-29208-FL F0ZZ-61042A82-A DASH PANEL, INSTRUMENT CLUSTER SURROUND M 90-93, BLACK $169.00
SPC-29209-FL F3ZZ-6113000-AAY CARPET SET, OPAL GRAY M 93, ALL HARDTOPS, WILL FIT EARLIER YEARS, COMES WITH PROTECTIVE PLASTIC IN PLACE THAT READS "DEALER MUST REMOVE PROTECTIVE COVER”, A MUST-HAVE FOR CONCOURS AND FUTURE THOROUGHBRED SHOWING $350.00
SPC-29219-FL F3ZZ-7613000-AAZ CARPET SET, BLACK M 93 CONVERTIBLE, WILL FIT EARLIER YEARS, COMES WITH PROTECTIVE PLASTIC IN PLACE THAT READS "DEALER MUST REMOVE PROTECTIVE COVER”, A MUST-HAVE FOR CONCOURS AND FUTURE THOROUGHBRED SHOWING $350.00
SPC-29210-FL F3ZZ-6120939-BAR MOLDING, DOOR SIDE CENTER, LH M 93 COBRA, TEAL $95.00
SPC-27938-FL F1ZZ-6127841-A QUARTER PANEL, LH M 87-93 HATCHBACK $499.00
SPC-29220-FL F3ZZ-76423A18-AAF MOLDING, CONVERTIBLE BOOT BASE, RH M 93 CONVERTIBLE, YELLOW $85.00
SPC-29221-FL F1ZZ-7645444-AAC TRIM PANEL, FRONT TRUNK M 91-93 CONVERTIBLE, GREY $75.00
SPC-29211-FL F2ZZ-6150124-AAJ BAG, SUNROOF STORAGE M 86-93 BLACK, CORRECT FOR 92-93 $49.00
SPC-29222-FL F1ZZ-7652700-A CONVERTIBLE TOP, BLACK M 91-93, TOP ONLY, NO REAR WINDOW $389.00
SPC-29212-FL F3ZZ-6161019-A FRAME, FRONT SEAT BACK, LH M 93 POLICE PACKAGE $125.00
SPC-29223-FL F0ZZ-7663804-CAJ UPHOLSTERY, REAR SEAT CUSHION M 90-93 CONV, BLACK LEATHER $159.00
SPC-30908-FL F2ZZ-7666600-AAP UPHOLSTERY, REAR SEAT BACK M 92 CONV, WHITE LEATHER W/BLACK PIPING, CORRECT FOR FEATURE CARS $159.00
SPC-29225-FL F3ZZ-7666600-CAC UPHOLSTERY, REAR SEAT BACK M 93 CONV, OPAL GREY CLOTH $79.00
See it wasnt that hard to do, there is the complete list fellas !
Here is the direct link http://www.npdlink.com/modules.php?name=NOS to the page for ordering info.
The wife says that too, but only in days that end in "Y"1993cobra wrote:Damn you are good, aren't you!
Only on the days that end in "Y"1993cobra wrote:Damn you are good, aren't you!
Your welcome sir.Ford wrote:Thanks for the NPD link. Very helpful.
If any of are serious about odering from them and wondering if the parts look good or not, let me know as I live about 10 miles at the most from there.
I would check it out for ya, I just dont want to be making runs up there all the time for people that are just looking for an opnion.
[quote="BADBOYSPACK"]If any of are serious about odering from them and wondering if the parts look good or not, let me know as I live about 10 miles at the most from there.
I would check it out for ya, I just dont want to be making runs up there all the time for people that are just looking for an opnion.[/quote]
Interested in this: SPC-27939-FL, E8ZZ-5230-F, MUFFLER/TAILPIPE ASSY, LH M 88-93 5.0 LX, LH, FULL FACTORY ASSEMBLY, INCLUDING BRUSHED STAINLESS TAILPIPE, N.O.S.. SOME ARE SLIGHTLY DAMAGED, WE'LL SELL ALL THE PERFECT ONES FIRST. $139.00
Was that your way of asking me to go look at it ?
Well do you need me to go look at it ?Ford wrote:Interested in this: SPC-27939-FL, E8ZZ-5230-F, MUFFLER/TAILPIPE ASSY, LH M 88-93 5.0 LX, LH, FULL FACTORY ASSEMBLY, INCLUDING BRUSHED STAINLESS TAILPIPE, N.O.S.. SOME ARE SLIGHTLY DAMAGED, WE'LL SELL ALL THE PERFECT ONES FIRST. $139.00BADBOYSPACK wrote:If any of are serious about odering from them and wondering if the parts look good or not, let me know as I live about 10 miles at the most from there.
