Long block value
Long block value
Just wanted to get some input on what a 150K long block that needs to be freshed up might be worth? This is out of #4785 and I'm thinking of selling it and buying a fresh short block as an opposed to tearing it down and installing new gaskets...etc. I want to install a set of GT40X heads, different cam, lifters, etc either way...
Any input would be appreciated.
Cobra #4785 Black/Opel cloth (sold)
Cobra #3593 Teal/Black, 1993 LX Hatch Calypso/Black 331 Stroker AFR 185s TKO 600 and 3:73s
Re: Long block value
It would only be worth anything to whomever owns car 4785 as it has a partial VIN stamped on it.93vnm wrote:Just wanted to get some input on what a 150K long block that needs to be freshed up might be worth? This is out of #4785 and I'm thinking of selling it and buying a fresh short block as an opposed to tearing it down and installing new gaskets...etc. I want to install a set of GT40X heads, different cam, lifters, etc either way...
Otherwise, it's not worth much IMO. I bought a worn-out shortblock like that for $100.
If you actually own the car it came out of, I say use the Original block, it has 150K on it, so it's a Proven Block, I am sure a good Hone and new rings and it will be good to go. Slap in a B-Cam, and a set of X heads and you'll have a nice little motor, Just as good as any Reman you going to buy, Probabbly better.93vnm wrote:Just wanted to get some input on what a 150K long block that needs to be freshed up might be worth? This is out of #4785 and I'm thinking of selling it and buying a fresh short block as an opposed to tearing it down and installing new gaskets...etc. I want to install a set of GT40X heads, different cam, lifters, etc either way...
Long block value
Thanks guys! I appreciate the input..... Probably will freshen the bottom end up and slap Gt40X heads and a B cam in it.
If anyone is interested in a set of stock gt40 heads contact me... I will have them off the motor very soon.
Long block value
I know I've read it in a thread on here.... where is the VIN stamped in the engine block??
On top of the block, close to where the rear lower mates to the lifter valley.93vnm wrote:I know I've read it in a thread on here.... where is the VIN stamped in the engine block??
Keep the Original heads, one day you will wish you still had them.93vnm wrote:Thanks guys! I appreciate the input..... Probably will freshen the bottom end up and slap Gt40X heads and a B cam in it.
Parts
Sounds like he didn't know what they were worth!
Re: Parts
He also gave me oem valve covers and 24 lbs injectors too. Deff a great deal.aaronlstiles wrote:Sounds like he didn't know what they were worth!
93 cobra #4892
12 boss 302#1749
76 f150 4x4 flareside
Looking for more toys.
12 boss 302#1749
