Water Pump NOS or OEM
I need one mine is leaking slightly anyone have one or know where I can get one? Thanks
http://www.americanmuscle.com/ford-waterpump-8693.html
I ordered this one, looks like it has a better design over the original for better cooling but it is still OEM FORD which is what I wanted. Anyone use one of these yet?
trackpilot
Post by trackpilot »
That's what i got. I got mine from latemodelresto though. No complaints. Easy install.
-Brian
On the hunt again...
Looking for a very nice all stock driver Red with NO Sunroof car!!!
Re: Water Pump NOS or OEM
JohnLynch wrote:I need one mine is leaking slightly anyone have one or know where I can get one? Thanks
Where is it leaking from? The seep hole or the metal plate between the pump and block?
There is a slight leak from the seep hole between the metal plate and the block there is some corrosion so its hard to tell I figure for $45 its worth it to change it out....
JohnLynch wrote:http://www.americanmuscle.com/ford-waterpump-8693.html
I don't think this will be the actual pump you will be getting, the new Ford pumps are made in china, and no longer have the Ford Logo on them. But If I am wrong let me know, I know the last one I got came in ford racing box, but once opened it was a china pump with a ford racing sticker on it
That sucks it showed a ford stamped part. How did the pump hold up? Do you know where you can get a Ford one?
Got my pump today. False advertising shows ford stamp on the website but it has a sticker says fomoco made in china :(
trackpilot
JohnLynch wrote:Got my pump today. False advertising shows ford stamp on the website but it has a sticker says fomoco made in china :(
Yeah. But honestly man does it REALLY matter? You're not gonna see the thing...
-Brian
Just sad they don't make our parts in the USA that's sucks lets start making our own stuff again!
I hate to say I told you so, If you want a NOS pump, you will pay top dollar. I have a few, but dont want to sell.
Also, you may have good luck at NAPA with a reman pump. Most of there re-man pumps are original ford housings. May be the same with autozone, all I can say is check it out.
I was not a fan of that Ford sticker, made in China!!
Its the point of do want Chinese parts on your car? I don't, maybe if I had a Kia...I try to avoid anything made in china, if there is a alternative I get it. I'll buy a Mexico water pump over Chinese.
trackpilot
I think John was talking about the sticker and it not having the original Ford stamp. Not about where it's made.
-Brian
I agree with Aaron check to see if you can get a re-man water pump and get an original, if not you might be able to re-use the old one if the gaskets were the only thing leaking.
There are several rebuilders that will rebuild your original part. Such as this one.
http://arthurgouldrebuilders.com/
