Cobra r oil cooler lines assembly ???
fstsvt03
Post by fstsvt03 »
I'm looking for a part number and or where I could possibly find a cobra r oil cooler lines and the piece on the engine block where the filter goes
Any help would be appreciated thanks
Re: Cobra r oil cooler lines assembly ???
My Mustang literature did not have Cobra R engine oil cooler part#s. The R-cars oil-to-air cooler was custom manufactured by a company called Hayden. You need these parts for an R or adding to a standard Cobra?
doesnt the R use the same oil cooler as a 94-95 regular cobra and a 93-95 lghtning? i have one from a 95 cobra , it mounts to the filter pad then the filter screws onto the cooler.
is it this type?
fstsvt03
Post by fstsvt03 »
Thinking about added to a cobra
And they look correct I haven't seen a cobra r in awhile to compare so maybe someone with an r can look at see???
Also where do to cooler lines run to I was trying to find some pictures but can really find any good images to compare
Careful, fst. This may be a bigger project than you expect. It's very likely that the oil cooler set-up from a 94-95 Cobra or a 93-95 Lightning is not the same as the one in the 93R and will be a tough fit. In the 93R oil cooler set-up, the hoses were connected from the adapter plate at the oil filter/engine block to the auxiliary oil cooler, which was mounted between the front bumper fascia inlet and the front of the radiator. Due to the limited space available between the radiator and the bumper fascia in the Fox Mustang set-up, the 93R front fascia support was completely revised from the standard Cobra bumper support set-up in order for the oil cooler assembly to fit.
the one pictured above, the hose go to the water pump and the intake
1993cobra wrote:is it this type?
If it's like these, probably the same as a SSP car. Might look on these forums http://www.specialservicemustang.net/forums/
http://www.sspmustang.org/forums/
fstsvt03
Post by fstsvt03 »
So the one pictured above would be for an ssp car ? The one for the cobra r goes through a cooler which was separate? Which was mounted behind the front bumper if I'm reading this correct ?
i looked in the SVT Recognition guide and it shows part numbers for the oil filter adapter, filter, lines, external cooler, and brackets. So the one pictured above is 93-95lightning, and 94-95 cobra.
1993cobra wrote:i looked in the SVT Recognition guide and it shows part numbers for the oil filter adapter, filter, lines, external cooler, and brackets. So the one pictured above is 93-95lightning, and 94-95 cobra.
In other words, not the same oil cooler set-up in the 93R.
I was saying it may be the same as an SSP car, that was a standard feature on them.
