Red/GrayLeather/Sunroof 66k miles #3581 $15k CO.
Re: Red/GrayLeather/Sunroof 66k miles #160 $15k CO.
wonder were you can buy that at? how much aluminum do our motors have under the hood?
The following underhood components are made of aluminum - upper and lower intake manifolds, thermostat, water pump, power steering pump and throttle body. The standard GT/LX 5.0L engine also had gray cast-aluminum valve covers, the Cobra's black valve covers are steel.JohnLynch wrote: how much aluminum do our motors have under the hood?
Not sure about the A/C compressor, alternator or exterior of radiator. I would treat these components as if they were aluminum for cleaning purposes.
Z282SLO wrote:The following underhood components are made of aluminum - upper and lower intake manifolds, thermostat, water pump, power steering pump and throttle body. The standard GT/LX 5.0L engine also had gray cast-aluminum valve covers, the Cobra's black valve covers are steel.JohnLynch wrote: how much aluminum do our motors have under the hood?
What cleaner is safe then? Maybe we should move this as a new thread under detail because this is new info!
You can order the aircraft/AL ok version on line. "Extreme Simple Green" http://gsa.simplegreen.com/gsa_products_extreme.php
