#2176 Red/Leather Sunroof 6200 miles Ebay TX.
1993 MUSTANG COBRA
ONE OWNER
6,241
NEVER BEEN WRECKED ALL ORIGINAL PAINT
ALL VIN CODES MATCH
AS CLOSE TO PERFECT AS YOU CAN FIND
THE COBRA IS ALL ORIGINAL AND HAS NEVER BEEN MODIFIED
ALL THE FLUIDS HAVE BEEN CHANGED
THE FOLLOWING NEW PARTS INSTALLED 02/16/2012
SERPENTINE BELT
UPPER RADIATOR HOSE
LOWER RADIATOR HOSE
STARTER
FRONT AND REAR BRAKES PADS
YOU WILL NOT BE DISAPPOINTED THIS COBRA IS TO CLOSE TO PERFECT AS THEY COME VALUES HAVE JUST STARTED TO GO UP ON THESE BEAUTIES
PLEASE CONTACT US WE ANY QUESTIONS WE HAVE MULTIPLE PICTURES AVAILABLE AND CAN ANSWER ANY OTHER QUESTIONS
1993 SVT Mustang Cobra
The inaugural year for the SVT Mustang Cobra, 1993, was also the last for the Fox-body Mustang. As such, the 1993 is the only Fox-body Cobra produced. Developed quickly with the use of off-the-shelf parts such as GT-40 cylinder heads from Ford Racing, the 1993 SVT Mustang Cobra boasted 235 horsepower from its 5.0-liter V-8, as well as larger vented front and rear brakes. Available only with a Borg-Warner T-5 manual transmission, the SVT Cobra’s 0-60 mph time of 5.7 seconds offered a distinct performance advantage over the mainstream Mustang GT. To help set it apart, SVT added subtle exterior enhancements, inducing a restyled front valance with round fog lamps, unique 17-inch seven-spoke alloy wheels, a rear deck wing and special Cobra badging.
Engine
Type: 90-degree, OHV Windsor V-8
Displacement: 5.0L / 302 CID
Horsepower: 235 hp @ 4600 rpm
Torque: 280 lbs.-ft. @ 4000 rpm
Bore x Stroke: 4.0 in. x 3.0 in.
Compression: 9.0:1
Suspension
Front: Modified MacPherson strut type, coil springs, anti-roll bar
Rear: Rigid axle located by four trailing links, coil springs, anti-roll bar
Brakes
Front: 10.84 in. vented disc
Rear: 10.07 in. vented disc
ABS: N/A
Wheels/Tires
Wheels: 17 x 7.5 in cast aluminum
Tires: Goodyear P245/45ZR-17 BSW
Performance
0-60 mph: 5.9 seconds (Road & Track)
60-0 mph braking: 140 feet (Road & Track)
1/4-mile @ MPH: 14.5 seconds @ 98 mph (Road & Track)
Production
Total Produced (Coupe Only): 4,993
- Black: 1,854
- Vibrant Red: 1,784 (1,775 Clearcoat / Paint Code ES & 9 Non-Clearcoat /Paint Code EY)
- Teal: 1,355
VIN:1FACP42D0PF142006
http://www.ebay.com/itm/1993-Ford-Musta ... Ou&vxp=mtr
ONE OWNER
6,241
ALL VIN CODES MATCH
SERPENTINE BELT
UPPER RADIATOR HOSE
LOWER RADIATOR HOSE
STARTER
Engine
Compression: 9.0:1
Suspension
Brakes
ABS: N/A
Wheels/Tires
Performance
Production
- Black: 1,854
- Teal: 1,355
- 1986Browns
Re: #2176 Red/Leather Sunroof 6200 miles Ebay TX.
High Altitude Principal Use? Whats that all about?
Original selling dealer is located in Santa Fe, NM. Cars originally sold in Denver, CO would also have that on the window sticker. I believe the EEC-IV was calibrated a little differently for these cars.1986Browns wrote:High Altitude Principal Use? Whats that all about?
If this car was a Red/Black combo I'd be all over it
Sent from my iPad using Tapatalk
I think this is the same car that sat on Autotrader for the last year and a half for $32k ish. It just dropped off Autotrader about a month or so back.
12SVT wrote:I think this is the same car that sat on Autotrader for the last year and a half for $32k ish. It just dropped off Autotrader about a month or so back.
X2 it was in Raleigh NC not far from me on autotrader like you said. If someone can post the Carfax it might show.
I'm local to this car if anyone wants it checked out. I didn't think from the pics it looked like a good example of 6k mile car, but I haven't checked it out up close...
Sure if it's not to much trouble, It would be nice for a forum member to check it out and give his personal opion on #
2176
2176
Gerbie28 wrote:Sure if it's not to much trouble, It would be nice for a forum member to check it out and give his personal opion on #
2176
I thought you were holding out for a Red/Black!
I am still holding out for Red/Black combo, just thought it would be nice of someone who lives close to check it out and give his opinion on the car for those interested.
