Looking to sell my 1993 Cobra roller.
Only 14k miles on car, Grey Leather seats in great shape. (front and rear). Interior pieces and carpet are Mint and included. (Not cut up at all, cage wasn't stared yet). Absolutely no rust. Car is as clean as you will find. The car has a little bit of history. Was stolen off the dealers lot in 1993, which meant the original title was listed as salvage. Carfax shows the 2nd owner and each owner after that as a normal title. So, currently the title in my hand is NOT branded with a salvage marking. Just mentioning it in the spirit of full disclosure. I have the printed car fax to show. Also have documentation for the SVT certification.
The car was originally black, but was painted the teal color it is now. At that time, Scott Rod Engine panels were installed, along with that they smoothed the firewall and engine compartment. Also has Polished caster/camber plates. (Radiator & mid-plate in the pictures is sold, so it won't be included) I do NOT have the original ecu for the car. Previous owner couldn't locate one and my plans didn't require using one, so I didn't push the issue.
I included a picture of when the interior was completely installed. At the moment, it is partially dis-assembled in preparation for a cage install.
The car currently has the rear area cut out for the mini tubs, but they haven't been completed. Rear area is setup to still retain a factory style tank. (straps for tank are in place) Not pictured, but I do have an aeromotive tank that will go with the car.
Car currently has the following brand new parts: (new, as in the car has never left the garage since they were installed)
--Strange Drag Brakes on all 4 corners
--Strange adjustable shocks/struts w/ coil overs on all 4 corners
--Brand new built, Braced, and narrowed 8.8 w/ 9" ends,Strange 35 spline axles & spool, 3.90 gear with Ford Racing Stud Girdle. Coil overs are in-board mount.
--Team Z upper and lower rear control arms.
--Team Z Anti-roll bar
--Team Z k-member and A-arms (SBF or Mod Motor, take your pick-I have both)
--Flaming River Manual Rack w/ Team Z Bump Steer Kit
--Team Z front suspension travel limiters.
--Team Z lightweight front bumper support
--Weld V-series front and rear. 17x4.5 front and 15x12 Double Bead lock rear
--Front tires are Mickey Thompson 26x6 Sportsman (Zero Miles) Rear are 275 MT Pro's (2 passes, borrows them in a pinch)
Looking for $15,000 (Firm, don't contact me if you are wanting to pay less). Serious Inquiries Only Please!!
If you are looking for a motor as well, I also have a 2015 Coyote/6R80/Ford Racing Control pack setup that I will be listing.
Vin# 1FACP42D9PF175067
BUILD #3063
http://forums.corral.net/forums/mustang ... miles.html
Teal/leather was Red Roller 14k miles #3063 WV. $15k
