You Tube Tutorial on How to Post Pictures
Something not working correctly or do you have any suggestions?
Moderators: 93Cobra#2771, SVT4942, SPEEDFREEK, 1993cobra, WillyB93, 93Cobra#2771, SVT4942, SPEEDFREEK, 1993cobra, WillyB93
Here is a video I found on you tube that may help those on how to post their pictures.
Probably not the best one. Hope it helps.
http://www.youtube.com/watch?v=ASoEF94sbBs
Also, you can get creative with photobucket. What I mean is... you can make you image smaller in size so it will fit into your Signature, or as your Avatar (under your user name). You need to use the HTML CODE for your Avatar upload and use the IMG CoDE for your signature..... in witch is the same as you would insert a picture into your message.
