Vin# 1facp42d0pf174731
Build# 2878
Born 5/17
Immaculate and perfectly streetable 585RWHP/570RWTQ 366 cubic inch, supercharged, 6-speed manual, Black/Black 93 Cobra built/tuned for 93 octane pump gas. 33,350 miles. 1500 miles on new engine. Details: Ford Racing Boss 302R block bored/stroked to 366 cubes (6.0L) with 10.25:1 compression, forged Scat lightweight crank+rods, Diamond pistons, Comp cam, stock 93 Cobra valvetrain, Edelbrock Victor Jr. aluminum cylinder heads, Edelbrock Performer RPM II intake manifold, Edelbrock 75mm TB, Vortech V-2 SQ S-trim Supercharger (13psi), AFM Powerpipe, 90mm MAF, FRPP 60lb injectors, FRPP aluminum radiator, BBK L/T headers w/matching short O/R H-pipe, Flowmaster American Thunder cat-back with turndowns, McLeod dual-disc clutch, D&D TREMEC Magnum Viper-spec 6-speed manual transmission/driveshaft, FRPP 3.55 rear gears, complete Baer brake kit (13" rotors at all 4 corners), custom subframes (welded), lightweight front-end cradle, Tokico 5-way adjustable front struts, caster/camber plates, Steeda rear lower control arms, Auto-Meter A-pillar mounted boost gage (black face), FRPP 03-04 Cobra 6-speed shift knob, 5% limo tint (all windows except windshield), Kenwood CD player, all 6 interior speakers replaced with Kicker speakers, replica rims widened to 10.5" with 315/35 Nitto NT05R drag radials in the rear, 7.5" wide Ford original factory rims with 245/45 Nitto NT555 tires in the front (I have the other 2 original factory rims as well). No sunroof. No rear defrost. Ashtray door works fine. This car is spotless, flawless and a complete jaw-dropper. It has never been to the track, but can be driven as hard as you want as it's built for it with a conservative, safe tune. It was completely stock with 16K miles when I bought it in 2004. All mods have been done by Alternative Auto Performance. I have receipts from all modifications, as well as all oil changes done at Ford dealers (Mobil 1 5W-30 fully synthetic oil and matching filter since I bought the car). This car looks, runs and sounds amazing.
