Oil pan bolt
Oil pan bolt
I changed the oil bout 3k miles ago and before I knew it forgot to put the rubber washer on the bolt, and noticed a lil drip residue on the oil pan later on, will it cause the oil to drip without the washer in place?
Re: Oil pan bolt
Yes it would. You can always just put a crush washer in they are like 50cents at advancedvinchez78 wrote:I changed the oil bout 3k miles ago and before I knew it forgot to put the rubber washer on the bolt, and noticed a lil drip residue on the oil pan later on, will it cause the oil to drip without the washer in place?
Re: Oil pan bolt
Auto parts stores should have the white nylon washers for the drain plug
- Mustang Enthusiast
Re: Oil pan bolt
Just spray some undercoat over the plug, it will help the dripping..
