#2774 Teal-GreyCloth
http://www.autotrader.com/cars-for-sale ... 7553&Log=0
Vin# 1facp42d3pf174139
Build# 2774
Born 5/6
Seller Comments
Performance Upgrades:
Sub-frame connectors
Strut tower brace
K-brace
3.55 ratio rear end gears with correct speedometer gear
New high performance 15:1 quick ratio power steering rack, new urethane rack bushings and new Moog outer tie rods
New AGR high flow power steering pump with new pressure hose and return line
New Ford Racing front lower Control Arms (SN95/96 bushings and self-lubricating ball joints)
New Eibach front and rear Coil Springs with new urethane bushings
New Eibach front and rear Sway Bars with new urethane bushings
Bilstein Shocks and Struts
Monroe heavy duty axle dampers
4 new Michelin Pilot Super Sport summer tires
New front brake rotors, inner and outer Timken bearings and grease seals and new Raybestos Heavy Duty brake pads
New rear brake rotors and Wagner Thermo-Quiet pads
New battery
New spark plugs (Autolite copper core), Accel distributor cap and rotor with brass terminals, new Jegs 49,000 volts coil, and Ford Racing 9mm spark plug wires
Oil and filter changed every 3,000 miles and always used Mobil-1 Synthetic motor oil
Always used Shell premium 91 octane gas. Techron concentrate Fuel injector cleaner treatment added to full tank of gas every 1,000 miles
Purchased car 15 Aug 2001 with 25,176 miles. Car has always been garaged and meticulously maintained and currently has 49,950 miles. Throttle response is instantaneous and immediate. Car has very strong acceleration and with the chasis stiffening, suspension, and steering upgrades this cars handling is superior to a stock setup.
Have the original window sticker, SVT Mustang Cobra brochure and owner s manual. Also comes with a custom car cover. The driver's power seat was converted to manual (all connections to convert back to power seat still remain) and Air Bag light is flashing. Other than last two items mentioned everything is in working order.
Image Image Image Image
800bman
Re: #2774 Teal-GreyCloth
Post by 800bman »
4 months later this one is back up for sale with a healthy price increase :)
Was 14.5k now 22k! Seems a tad bit high to me.
Bguetter
Post by Bguetter »
I don't want to sell it, but buying a house and need to make room. I got a heck of a deal when I bought it, and I agree, it's priced it a little high. Probably in line if it was 100% original, we'll see how much the suspension mods take the price down.
