Power Window repair
93Cobra#2771
Power Window repair
Post by 93Cobra#2771 »
Latest project: Driverside power window stuck in the down position.
I've owned #2771 since 1995. 46,xxx miles. The driverside window has always been a little sketchy going up and down. Mainly down. On the way down, it wasn't a smooth movement, tended to kind of speed up and slow down.
Finally, it went down and wouldn't go back up. I could hit the switch and the voltage gauge would jump, so I knew it wasn't the switch. Had to be the motor or something binding.
After doing a little research, apparently it was common for some little plastic pics within the regular assembly to fall apart over time. Likely the culprit, but wouldn't know until I pulled it apart.
So, door panel off, plastic sheeting off (again) and able to access the motor/regulator assembly. Fished it out through the speaker hole (lots of fun and sharp edges). Pulled the assembly apart and sure enough, the little pucs inside assembly were in pieces and binding it all up. You can by an entire rebuild kit for that assembly for $20 or just the pucks for $5 or so. Not knowing what I'd need, I got the kit.
All went back together as it came apart. I cleaned all the gunk and bits and pieces and greased the assembly with the provided grease. No grease in teh puck area, just the outer area.
The assembly was a bit tricky to go back together with the new pucks. A slight interference fit and tight quarters. Used a small plastic prybar to help coax it all back together.
Plugged back in prior to bolting back together and worked like a champ. Previously verified the window would go up and down by hand, so I knew it wasn't binding.
No pics of the process but here are a few of the interior of the assembly with the bits and pieces of the pucks and their carnage.
https://flic.kr/s/aHsmUDeG47
Might even get the pics to embed in here once I dink around with flick some more. Been a LONG time since I had to img code drop pics, gotten spoiled with other forums allowing directly import of pics.
*Edit - figured it out
*Edit #2 - DO NOT buy a new power motor assembly unless you can verify the motor is bad. The replacement stuff isn't nearly as good as the OEM, and they are very noisy and rough.
ImageIMG_7773 by 93Cobra#2771, on Flickr
ImageIMG_7772 by 93Cobra#2771, on Flickr
ImageIMG_7774 by 93Cobra#2771, on Flickr
ImageIMG_7775 by 93Cobra#2771, on Flickr
SVT4942
Re: Power Window repair
Post by SVT4942 »
Nice write up! Yeah, my high mile teal (Short Circuit) needs some window attention. Passenger side window rolls down from the driver side, but does not roll down on the passenger side. I’m betting it’s just that switch.
93 EY/C6 13C #12
93 RD/DJ #2304
93 RD/DJ 13C #4942
93Cobra#2771
SVT4942 wrote: Thu Apr 01, 2021 8:41 am Nice write up! Yeah, my high mile teal (Short Circuit) needs some window attention. Passenger side window rolls down from the driver side, but does not roll down on the passenger side. I’m betting it’s just that switch.
Yes, I'd say the switch is the culprit. Likely just needs pulled and light cleaning with some CRC contact cleaner, perhaps even under the button itself. Button it back together with some dielectric grease at the connector and see what happens.
SVT4942
Post by SVT4942 »
Nice! I have some CRC too. I’ll give that a shot. Thanks
93 EY/C6 13C #12
93 RD/DJ #2304
93 RD/DJ 13C #4942
SLOWBRA
Post by SLOWBRA »
This is a great write up. Thanks for sharing.
2004 Comp Orange Cobra Vert
2000 Cobra R
1995 Cobra R
1993 Cobra
2020 F150 Roush 5.11 Tactical
SLOWBRA wrote: Fri Apr 02, 2021 7:45 am This is a great write up. Thanks for sharing.
X2! Very helpful info.
I always cleaned the grease out and added 3 quarter inch nuts, to the spaces,
93Cobra#2771
Ive always heard that can cause issues, as the plastic is the weak link on purpose to fall apart if something gets out of line. However, I almost did it that route until I saw that the pucks were so inexpensive.
Got a part number for the kit you bought............cuase I'm lazy you know and just want to click a link. :P
